looking for an other CAD App
Thanks: 53 times Was thanked: 96 time(s) in 64 post(s)
Just an interesting add to this conversation…
Solidcraft has now got plug ins, from version 0.44
Quick YT link to see a gear plug in It is impressive how this is developing so quickly, as is PhysCAD, and both respond well to user feedback.
Mike
Another one, works in your browser… early days but just posting for reference, does have a CAM package too
CADivari Opened pretty fast in Safari on macOS, just going try and edit a STEP file**
Mike
PS, it can’t do that** pretty limiting, but might be useful.
Edited by user Wednesday, November 18, 2026 3:55:29 PM(UTC)
| Reason: Doesn’t import STEP
Thanks: 361 times Was thanked: 269 time(s) in 176 post(s)
Of all the alternative CAD programs, Plasticity is simply the best and the most intuitive to use. It also has better snapping capabilities and automatic guide lines than SharkCAD. I bought it when it was recommended here.
Thanks: 7 times Was thanked: 95 time(s) in 54 post(s)
I invited Mike from PhysCAD to join the forum:
Hi Mike,
the PunchCAD users desperately are looking for an ViaCAD and SharkCAD alternative. This are one of the best useable tools (not to compare with Fusion, etc), but it's still bugy, slow (no native Apple Silicon and Metal) and we don't know what happens in future after Mac Rosetta will be depleted.
https://www.punchcad.com You could join our conversation on
https://forum.punchcad.c...ts&m=43804#post43804 and give some insight of your CAD and read what users are looking for.
Mikes (PhysCAD) answer:
Thank you Jarno! This is great to know, and sounds like just the thing this was built for. I will try and hop on when I can, but to be honest, we are slammed with development work at the moment, so my free time is very limited. My suggestion is to have some of those folks jump on our discord server, that's the easiest way for me to handle feature requests at the moment.
https://discord.gg/fev2VpyPWW forwarding this to ryan as well, as maybe he can jump on the forum and get the low down as well.
1 user thanked relaxibus for this useful post.
Originally Posted by: MPSchmied Of all the alternative CAD programs, Plasticity is simply the best and the most intuitive to use. It also has better snapping capabilities and automatic guide lines than SharkCAD. I bought it when it was recommended here.
But how do you handle modifications? E.g. you need to move a hole, or to modify a fillet/chamfer? I used Vectorworks in the past when it was no parametric, a nightmare.
So can you use Plasticity as a Shark alternative?
Edit: No DXF/DWG import for Mac?? This is a annoying!
Edited by user Friday, November 20, 2026 5:45:08 AM(UTC)
2 users thanked relaxibus for this useful post.
Originally Posted by: relaxibus So can you use Plasticity as a Shark alternative?
Sure, Plasticity doesn't have all the features I need either. But I prefer Plasticity's Drafting Assistant (LogiCursor) over the one in Shark.
And you can move holes: Select the inner face of the hole and press G. This brings up a kind of gizmo that you can use to move the hole.
Quote: Moving an Existing Hole in Plasticity There is actually a direct way to do this. In Plasticity 2025.3, moving circular edges on solid bodies was also improved.
Step-by-step instructions Open your model in Plasticity. Press 3 to switch to Face Selection mode. Select the cylindrical inner face of the hole. Press G to activate the Move tool. Move the hole along the desired axis using the gizmo, or enter a precise displacement value. Confirm the operation. Alternative method (Plasticity 2025.3 and later) Press
2 to switch to Edge Selection mode, select a circular edge of the hole, and press
G to move it.
For complex holes, the surrounding geometry may limit what modifications are possible.
This method is intended for repositioning an existing hole in a solid body, not merely moving a circle in a sketch.
Edited by user Friday, November 20, 2026 1:58:19 PM(UTC)
2 users thanked MPSchmied for this useful post.
Thanks: 158 times Was thanked: 130 time(s) in 89 post(s)
Originally Posted by: relaxibus PhysCAD ...
Expandable menus.
I'm still on SharkCAD Pro v12, and I haven't trialled v16. I can't understand why the Inspector had not been made expandable before v12.
Surely, people have long layer names that cannot be differentiated if the canvas cannot be expanded. Ths severe limitation makes me dig in the Concept Explorer and prefix layer names with numbers or eye-catching symbols or characters.
Edited by user Friday, November 20, 2026 2:56:20 PM(UTC)
1 user thanked ZeroLengthCurve for this useful post.
Thanks: 3 times Was thanked: 14 time(s) in 12 post(s)
Apparently V18 has been released as a 1000 dollar upgrade (!) and it’s supposed to be Aplle silicon native. Has anybody tried it?
1 user thanked Claus3 for this useful post.
LOL, upgrading from a five-year-old version of SharkCAD to SharkCAD Pro is cheaper than upgrading from SharkCAD Pro 5 years old or v 17 to 18.
Edited by user Wednesday, November 25, 2026 5:02:48 PM(UTC)
Thanks: 39 times Was thanked: 19 time(s) in 16 post(s)
trying trial now. it is fast. resolution ok on retina screen. the fillet tool icon looks to much like changer tool icon. most icons stayed the same (good!!!). I think they looked better a few versions back, something with the blur, but they are the same. snaps work but occasionally arcs are not magnetic to new new element start, like no quadrant, tan, or on. it feels like viacad, so I call that a win. memory use on Mac is 25 percent of v16 same file same operations. faster and smoother too. cpu/gpu usage up a lot. no hesitation redrawing screen just by adding line. 10 minutes in, this is what 16 was supposed to be.
1 user thanked memphisjed for this useful post.
@claus3
Thanks for the heads up, this was a quiet release, only just seen it myself.
I think they have made it a single operating system licence now, so you choose Windows or Mac
Also the Powerpack option that I have is extra again, as are several other add-ons.
Mike
@memphisjed is there a beta program, or are you just using the 30 day trial?
I’d be super interested in any bug fixes, and how good the STL to solid conversion is.
Edited by user Thursday, November 26, 2026 3:49:58 AM(UTC)
| Reason: Typos et al
(1,058kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
On the Punchcad website it says powerpack 2.0 tools built-in. I assume it means no extra cost. However I think they made a mistake with the pricing. Upgrade to SharkCad Pro from non-pro sharkcad is 799. Upgrade from Pro to Pro is listed as 999. I think they made a mistake and that the pricing is in fact 799 from pro to pro. Make sure before you order. I already complained about the 999 price, I’ll post the response if I get one but the current pricing makes no sense.
