Originally Posted by: 24c
@claus3
Mike
@memphisjed is there a beta program, or are you just using the 30 day trial?
I’d be super interested in any bug fixes, and how good the STL to solid conversion is.
I have the demo. A little gun shy after 16. Not that vcp cost a lot in real cad money but cost a fortune in time learning and finding one that is fluid to your work and work style. Vcp is not perfect but is one of the few with drawing dominant window and not hundreds of pop out and does organic/curves well. Bugs so far found:
Fillet tool is same icon as chamfer.
Paper space views can not change direction (top, bottom, front, iso..) from the red frame box.
Loose start element snaps sometimes if you move to new window and then back.
Setting super fine resolution and fine resolution are the same but apply button results and results after restart are different. This is minor as most of us likely run superfine at 1.1 anyway (finest it gets- so same settings) and never change after our initial setting it up.
I have power pack on 16 but it is not showing on my demo. So have no idea about stl to real is. That is never a small feature- I have about the same luck with it in power pack as fusion -even sending it to Autodesk supercomputers and back. On Mac now with m4 so I have staggering more single thread power than my last uses with intel.
The icon have to much blur imo. They look better but usability/access is better with the no blur. They are smaller in small icon setting than before-
I have physcad to see about the cam, I really want to stop giving Autodesk money. Cad wise if you are doing simple things it works. It’s feature recognition like remove chamfer are hit miss, things you want on the cam side of modeling is all I really tried. I like direction they are taking it- but it will never be a design cad first program.
All testing Mac air 14” retina with 21 gig ram, m4 chip, macOS 27.?
