Solid Modeling
Gaps detected in profile. - Can't find it (#4137)
Hello,
I have this problem now since days and can't solve it. I am new with Shark FX in general and I am using Version 8.
What did I do?
1. Imported a DXF from my previous 2D CAD solution.
2. Removed some pieces from the drawing. And there are still some pieces in layers which are hidden right now.
3. I made sure, that the whole contour line is one single line. See the picture attached, I was able to hatch it.
4. Now I am trying to extrude it with "Extrude Solid" and I am getting the "Gap detected.." message.
I can not find where the gap should be. So what can I do to extrude it finally and continue with the rest of the work.
Any advice is appreciated.
Thanks for your help.
Dieter
radler64 attached the following image(s):
(152kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 181 times Was thanked: 159 time(s) in 109 post(s)
Hi Dieter, I also have this problem with imported .DXF files. I can't explain how it works, but if I erase a line or 2 and redraw the lines, especially at the end of a radius, the file will extrude. Try this on the file without any hatching. Larry
As Larry says, try excluding the Hatching in the Extrusion. Martin.
Originally Posted by: L. Banasky Hi Dieter, I also have this problem with imported .DXF files. I can't explain how it works, but if I erase a line or 2 and redraw the lines, especially at the end of a radius, the file will extrude. Try this on the file without any hatching. Larry
I did what you've suggested - and it worked.
I deleted one of the radius and recreated the line.
And I can extrude it now.
Thanks to both of you for the quick help.
Best regards
Dieter
(18kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Solid Modeling
