3dup
#1 Posted : Thursday, April 24, 2014 6:25:25 AM(UTC)
3dup
Was thanked: 5 time(s) in 3 post(s)
Hi
Is there any problem with V9_1104 build? I have made a lot of test on it now.
1)
When using push/pull on a 2d object, sometimes it highlight the surface in "some red color" sometime it not?
2)
On a 3d block i place a rectangle 2d. Then I select "Solid Trim" and highlight the new rectangle then is remove the main block not making a hole in it?
3)
When placing a circle and do the same, it put arrow on the circle, as expected. Them I click one more time, and then I have my nice hole.
This is frustrating?
