rockyroad_us
#1 Posted : Saturday, February 12, 2011 1:05:53 AM(UTC)
rockyroad_us
After seeing the video of blending two spheres using the blend command, I took with excitement to using it between the radial faces of two cylinders for trying out other methods for drafting one project.
After several attempts, I cannot blend the two cylinders and I'm asking the fans here whether there's a limitation on the blend tool.
You figure that if the blend tool can blend between spheres, the tool should be able to blend between cylinders. I know that It can blend the radial wall with a flat wall of a box.
blendcylinderface.sfx (28kb) downloaded 4 time(s).
blowlamp
#2 Posted : Saturday, February 12, 2011 4:39:38 AM(UTC)
blowlamp
It only seems to work if the cylinders are in contact with each other.
Martin.
rockyroad_us
#3 Posted : Saturday, February 12, 2011 8:41:16 AM(UTC)
rockyroad_us
I overlapped them and got one side to blend.
Unfortunately, this beats the purpose as my cylinders have to be spaced away and not touch or overlap.
I could have just joined the cylinders and blend each oppose edge rather than use faces.
