I'm having trouble with the two rail sweep function. See video below. The function appears to be failing. You see, the sweep follows the first rail but not the second rail. Any help is appreciated.
2railprob.sfx
(17kb) downloaded 6 time(s). 2railprob_0.mov
(156kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
It gives a satisfactory result if you select the arc and chord, and choose two-rail swept solid rather than surface.
(165kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
