Gary
#1 Posted : Friday, February 19, 2010 5:47:33 PM(UTC)
Gary
Hello Tim,
It would be helpful if you could choose what 2D projection view the 2D/3D toggle defaulted to. Often front or side is of more value than top.
Perhaps a preference to set the default projection and add to the right click on 2D/3D toggle the top/front/side options for altering the current file setting.
Gary
misterrogers
#2 Posted : Thursday, February 25, 2010 8:17:20 PM(UTC)
misterrogers
Gonna have to second that. Because, unless i'm detailing a window-console whose back panels are just as complex as the front, I typically require front and end view more than anything.
ttrw
#3 Posted : Friday, February 26, 2010 6:38:25 AM(UTC)
ttrw
Can you not change the orientation of the part in the drawing window? Highlight one of your views and a boundary box will appear. In the top left of that box is another box. Click on that and further options appear- like changing part orientation.
Screen shot 2010-02-26 at 12.35.49.png (25kb) downloaded 4 time(s).
Screen shot 2010-02-26 at 12.37.19.png (26kb) downloaded 4 time(s).
