lovebugjunkie
#1 Posted : Saturday, January 8, 2011 7:11:44 PM(UTC)
lovebugjunkie
Trying to import a .skp file from sketchup. I get an error message saying missing library on these two files.
Sketchupreader.dll and atl71.dll
Both files are in the following location.
C:\Program Files\Punch! Software\ViaCAD Pro v6\exe
I did a default install, running windows 7 32bit
Any suggestion on what I have I have wrong?
Sorry this is in the wrong place, found the problem also reported by another user.
#2 Posted : Monday, January 10, 2011 12:25:55 PM(UTC)
What build do you have?
David Gross
#3 Posted : Monday, January 10, 2011 4:49:41 PM(UTC)
David Gross
Download and install Microsoft Visual C++ 2010 Redistributable.
David Gross
Dmg Design
Colgate, Wi.
lovebugjunkie
#4 Posted : Thursday, January 13, 2011 9:49:16 PM(UTC)
lovebugjunkie
Running v6.0.0 build 852.
Will look into the C++ 2010 Redistributable
lovebugjunkie
#5 Posted : Thursday, January 13, 2011 9:58:17 PM(UTC)
lovebugjunkie
Installed C++ 2010 Redistributable and rebooted the pc, still get same error message when I try to import a sketchup file.
#6 Posted : Thursday, January 13, 2011 10:24:17 PM(UTC)
Private email me and I will get you another build. Let's see if the newer build solves the problem.
tim.olson@evo-soft.net
