Glenn Karnish
#1 Posted : Tuesday, July 21, 2009 8:51:03 AM(UTC)
Glenn Karnish
I was trying to non-unform scale an oval section made of 4 arcs and got the following message.
The xyz scales are equal. A uniform scale will be applied. Anyone see this before?
GK
zumer
#2 Posted : Tuesday, July 21, 2009 9:16:21 AM(UTC)
zumer
Choose differential scale, and apply the different factors in the boxes. If you haven't applied different factors, ie the factors are the same, using this mode, the message you saw appears. It's not an error message, just a reminder nudge.
murray
not an error.PNG (41kb) downloaded 5 time(s).
Glenn Karnish
#3 Posted : Tuesday, July 21, 2009 11:05:32 AM(UTC)
Glenn Karnish
Murry, thanks for the help. I now see how this works, however I was under the impresssion that the scale function would let me mouse drag. I was wrong.
I have placed this as an enhancement request under Suggestions.
GK
