Import/Export
Can't Import SketchUp Files (#3210)
Can't Import SketchUp Files It tells me I lost SketchUpReader.ll, atl71dll I just updated to Windows-7_32 Now it will not let me download new or old files from SketchUp Files. Could someone help me put back the (SketchUpReader.ll, atl71dll) Flie :confused: Thank You Redss
Originally Posted by: Redss Could someone help me put back the (SketchUpReader.ll, atl71dll) Flie
a reinstall (main application is sufficient) should create the files.
hth,
Norbert
Hi posh.de I reinstall Punch! ViaCAD Pro v6 3 times Sunday :confused:Each time I truned off my AVG.Would you think if I found that file and just tryed to reinstall it.
Originally Posted by: Redss ...ViaCAD Pro v6...
if the program installation went fine, the files should be localized in the VC subdirectory "\exe\"... besides the installer has a problem.
btw, the exact VCP build number (see help menu > about...) could be handy for a further processing.
hth,
Norbert
Hi Redss Did you try reinstalling Sketchup Regards Jason
Hi jdi000 I don't have Sketchup installed I just us somethings from there 3D Warehouse an download them.I have been doing that for about a 1-1/2 years. I just reinstalled ViaCad Pro v6. Still doing it:confused:I did fine the file (SketchUpReader.ll, atl71dll) I do not know how to just install that file? I will install Sketchup program.
Originally Posted by: Redss Hi jdi000 I don't have Sketchup installed I just us somethings from there 3D Warehouse an download them.I have been doing that for about a 1-1/2 years. I just reinstalled ViaCad Pro v6. Still doing it:confused:I did fine the file (SketchUpReader.ll, atl71dll) I do not know how to just install that file? I will install Sketchup program.
Hi Redss
Sorry I misunderstood what you were doing, you don't need to install sketchup... The dll file could be corrupt.
You just loaded VCP onto Win7 computer and the sketchup import does not work, or it worked before and stopped working.
And you reloaded and it still does not work.?
Late Fri. I install Windows-7 and I had to reloaded my programs. Sunday I went into VCP and went to 3D Warehouse and that is when I notes it was not working.It worked fine before I put W-7 on.
Hi
I think I changed the path on my computer last week.
Could you guy's help me get my computer back on the right path.
Here is what it tells me and I think ViaCad can not fine the file on my computer.
I am not sure how to get the right file on the folder here is what It looks like now :mad:
Thank You have a nice day
Redss attached the following image(s):
(32kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Redss
Private email me at
[email protected] with your current build. I'll send you the latest vcpro v6 installer to make sure its not an installer issue.
Import/Export
