I need to make up some bodies to sit around a table. If anyone would have some tips. Thank You
Thanks: 10 times Was thanked: 35 time(s) in 16 post(s)
I would download DazStudio from
http://www.daz3d.com/i.x/softwa...73ba07c5a762bab4a7f755/? Choose a low poly preset from their free content or search for a suitable poser file ie google whatever+poser
bring your cad model into DazStudio via dxf sit your figure on it delete cad model & export figure as dxf. Drop into Concepts/ViaCad.
If you want UV textures you will need to export for a 3D program that supports uv mapping and bring both cad model & figure there to render.
BB
Thank You bbuxton I will have to play with it I would like to turn them in to STL flie for another e-Cabinet :) program
You might look at:
http://www.cadhuman.com/ that contains the best CAD-suitable models of humans that I've seen so far. However, the trial that I had of a hand imported as *a whole*, rather than as a collection of parts.
I hope there might be a workaround, as the model is excellent.
YOU might look at:
http://www.cadhuman.com/ ... that contains the best CAD-suitable models of humans that I've seen so far. However, the trial that I had of a hand imported as *a whole*, rather than as a collection of parts.
