howhurley
#1 Posted : Monday, May 24, 2010 10:36:37 AM(UTC)
howhurley
Hello! I am a new user of ViaCAD Pro 6.0 and designing an injection molded part. I have drawn my part but do NOT understand how to get a draft of 2 or so % in the shell. Is it even possible???
#2 Posted : Monday, May 24, 2010 3:28:58 PM(UTC)
Is the basis of your part a simple extrude - if so, then the extrude solid tool allows for draft, so long as your sketch is planar.
If you are drawing something more complex, the answer is likely no. Then you must construct the draft
If you're working in surfaces, as I often do ... then it's helpful to tangent match your constructed surfaces into a drafted dummy reference surface - that is when Tim's fixed the 'match surface' tool : )
Not sure that will have helped you .. or Tim.
#3 Posted : Monday, May 24, 2010 5:11:22 PM(UTC)
Have you tried to use the parting line tool, I am not sure how complicated your part is?
NickB
#4 Posted : Monday, May 24, 2010 6:55:15 PM(UTC)
NickB
I am assuming that you have tried the draft tool ?
The way I use the tool is to create the basic external form as a solid, add draft, then shell.
http://screencast.com/t/NWNjZDZiZD
Shark FX 9 build 1143
OS X 9.5
matter.cc
