ToreT
#1 Posted : Tuesday, December 14, 2010 1:21:48 PM(UTC)
ToreT
Norway
Say you want to draw a helix has a draft angle and then this helix is swept to resemble a spring. With no load this spring shall have a constant lead.
Suppose this spring then is being compressed and you want to draw it in this state, then that spring would have to have a variable lead since the smaller diameter end would be stiffer.
My suggestion is simply: add the variable lead parameter!
#2 Posted : Wednesday, December 15, 2010 11:51:15 PM(UTC)
Was thanked: 164 time(s) in 101 post(s)
I like your suggestion ToreT !
