2D Drafting
possible problem with 'trim region' tool?... (#2619)
Hi, A friend of mine who has purchased VC6 has 'discovered' that the trim region tool seems to not work in the expected way. I have tried, and confirm his findings. If one draws a random circle, then a straight line intersecting the circle twice, clicking outside the circle does not trim the lines to the circle as expected. If one clicks inside the circle, in either region defined by the line, the correct trim occurs. I tried several variations of this, and in each case, clicking outside the circle did nothing. My friend had actually drawn a line from the centre, and circular arrayed that to create spokes, which extended beyond the circle. He was unable to region trim the spokes back to the circle. I know he could/should have drawn the line to the correct length originally, but its the behaviour of the tool I wish to ask about. Can anyone confirm that this is a possible bug, please? Regards, Ian.
Ian Kirby Wollongong Australia
I'm not finding that with PC build 852, Ian.
Hi Ian, The Region trim tool is for use on closed regions, so lines outside the circle will not trim. Instead of drawing lines, draw diagonal polygons, then you will see how the tool should work. - Steve
2D Drafting
