Is there any way to move a vertex (eg corner of a plane) to a specified coordinate. I have not been able to work this out. I have a four corner plane and I want to specify where each corner is in the 3D world. Using ViaCad 3D 6 Thanks Matthew
Originally Posted by: matty47 Is there any way to move a vertex (eg corner of a plane) to a specified coordinate. I have not been able to work this out. I have a four corner plane and I want to specify where each corner is in the 3D world. Using ViaCad 3D 6 Thanks Matthew
Select the vertex using the arrow tool. Then select Verify:XYZ. In this dialog box, you can also change the xyz to a new value.
