Thanks: 231 times Was thanked: 184 time(s) in 111 post(s)
It was possible to set text size inferior to 1 point before (using menu & sub-menu), now it is blocked to 1 point minimum. The workaround is to chose a small size in mm, but where is the logic ? JL
Originally Posted by: jlm It was possible to set text size inferior to 1 point before (using menu & sub-menu), now it is blocked to 1 point minimum. The workaround is to chose a small size in mm, but where is the logic ? JL
Hi JL,
I seem to be able to set it 1 one point using the User specified option. This is the dialog that displays text height in model/point sizes.
Originally Posted by: Tim Olson I seem to be able to set it 1 one point using the User specified option.
Thanks Tim,
Actually I'm talking about size smaller than one point (ie 0.5 point).
When I design small things, 1 point text is huge...
JL
>>Actually I'm talking about size smaller than one point (ie 0.5 point). Ok understand. >>When I design small things, 1 point text is huge... I noticed that in your offset bug thread :) Tim
