#1 Posted : Saturday, May 12, 2007 4:22:40 AM(UTC)
6 bugs on one file :
None are really blocking, just potential improvments ;)
1-Corner trim not operating :
very frequent with arcs, depending on the length of the elements.
Workaround is to make them longer in object info, and trim afterward.
2-Skin solid with guide :
Not working if I select the green profile first.
Bad message : "at least 2 distinct profiles are needed"
There maybe gaps in my geometry (it happens sometimes), but the program should tell...
3-Skin solid with guide :
Working if I select the red profile first, but generates a strangly transparent solid.
I got this a couple of times in the past.
4-Verify / check object :
Should detect a defect on the strange solid...
Workaround : stitch solid can repair it.
5-Text boxes should show the borders when selected (one clic).
How do you resize them ?
Workaround : show points of the box object.
6-Rotate view and the text boxes are all troncated...
JL
Bug solid.cu.zip (70kb) downloaded 5 time(s).
#2 Posted : Saturday, May 12, 2007 5:16:16 AM(UTC)
I have suffered these
Did you send these to Todd
#3 Posted : Saturday, May 12, 2007 6:00:07 AM(UTC)
Yes, I sent them yesterday.
JL
NickB
#4 Posted : Saturday, May 12, 2007 5:28:36 PM(UTC)
NickB
Is it just me, or does it feel like there is LESS quality to V4 sp3 than almost any other release ?
Is this the future of CU under Punch ?
Shark FX 9 build 1143
OS X 9.5
matter.cc
Todd Quinlan
#5 Posted : Thursday, May 17, 2007 8:18:02 AM(UTC)
Todd Quinlan
I have these bugs and have put them into the trackers for the developers.
As for the future of CU, Nick i assure you my goal here is to take all these issues to the developers and help Tim make sure that the Concepts line is better than ever under Punch's watch.
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
#6 Posted : Thursday, May 17, 2007 1:10:37 PM(UTC)
I certainly hope so .. this software's certainly had it's share of honkers over the years.
The feature tree functionality for example is still littered with 'issues'.
Hopefully also, there'll be more internal testing this time round to pick up problems before end-users have to
#7 Posted : Friday, June 22, 2007 12:25:19 PM(UTC)
Any news from developers ?
I'm using guide skin solids a lot on my projects, it's a marvelous tool but I'm loosing too much time on workarounds.
JL
