#1 Posted : Monday, April 9, 2007 2:50:34 PM(UTC)
This is an old bug, still here.
-Make a helix along z axis
-Sweep one rail a profile on the helix (ie. to make a screw).
-Select all, and move along xy plane.
---> The swept solid inflates like my eyes :eek:
I have to remove links everytime I want to move a screw.
Please address.
JL
I still cannot upload anything. I am alone ?
#2 Posted : Monday, April 9, 2007 3:08:07 PM(UTC)
No, I can't upload anything either
I'd at least like to be able to upload screenies .. so people can have a clue what I'm ragging about !
JL .. we need you here .. do be careful not to explode when you screw
#3 Posted : Monday, April 9, 2007 3:55:41 PM(UTC)
Thank you Jol,
Well, I'm just turning nut.
JL
#4 Posted : Tuesday, April 10, 2007 1:56:14 AM(UTC)
Jol,
I see you're now a good "Member"
Congrats,
JL
#5 Posted : Tuesday, April 10, 2007 2:05:49 AM(UTC)
I'm a member .. not the first time I've been told that !
Keep up the good work, Junior
#6 Posted : Saturday, May 12, 2007 4:42:17 AM(UTC)
Please address.
JL
Here's the file :
(Todd couldn't repeat this one, can anyone help ?)
BugScrew.cu.zip (331kb) downloaded 5 time(s).
After translate.png (40kb) downloaded 5 time(s).
Todd Quinlan
#7 Posted : Thursday, May 17, 2007 8:45:34 AM(UTC)
Todd Quinlan
With your file, I was able to recreate your issue, but as you can see with my file this does not happen. We must be doing something different. I followed your directions again.
-Create a helix along the z-axis
-one rail sweep an object around the helix
-Select all
-Move along the xy plane
spring-screw bug.cu (282kb) downloaded 5 time(s).
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
Todd Quinlan
#8 Posted : Thursday, May 17, 2007 9:24:30 AM(UTC)
Todd Quinlan
JLM, after further investigation into your drawing, I found a random point attached to the swept profile, when i removed this point your issue is gone.
-Go to your concepts explorer
-Select the swept profile
-On the feature tab expand part_6447352
-Expand sweep-6447322
-Delete the point
-Close the concepts explorer
-Select All
-Translate
I do not know why this point was causing the issue, that is another investigation.
Todd Q
#9 Posted : Thursday, May 17, 2007 10:23:19 AM(UTC)
Thanks Todd,
I agree, as you say it works.
Thank you for pointing out that point.
Mysterious point :
- I didn't create it.
- It is not visible in the window, only in the tree.
- Select mask doesn't catch it.
Other points :
- copy the solid with history doesn't copy the history.
- translate-copy doesn't copy the issue...
JL
Guest (13)
