New bug with several files open (#30)
Thanks: 231 times Was thanked: 183 time(s) in 110 post(s)
I had two files opened at the same time.
After some time and playing with other softs, I saved the first file and closed it - OK
When the second file appeared on the screen, all the CU menus had gone except "file".
Same as if there was no file open.
----> Impossible to save or even to close.
See on the screenshot attached.
Quit is the only way out.
I'm lucky I didn't do too much work on that one...
JL
The attachment size limit for PNG is really too small!
(28kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 6 times Was thanked: 28 time(s) in 15 post(s)
jlm wrote: Hi, I had two files opened at the same time. After some time and playing with other softs, I saved the first file and closed it - OK When the second file appeared on the screen, all the CU menus had gone except "file". Same as if there was no file open. ----> Impossible to save or even to close. See on the screenshot attached.
Have a similar problem here under OSX 10.4.8 on MacPro.
Safari will highjack my CU-menue-bar and the keyboard when switching to it.
Only way to get back control is klicking on the CU icon in the dock. Klicking on a CU-window wont do it.
ALBAN
