Trfsrfr
#1 Posted : Sunday, November 20, 2011 11:23:55 AM(UTC)
Trfsrfr
How can I join two lines at their endpoints, and be able to extrude them without losing the 90 degree corner.
In the attached photo, I made two circles, trimmed them into half-circles, then drew lines to join them, then used the join tool, and extruded it.
But it always rounds off the corners, and I wanted those endpoints.
Thanks-
Trfsrfr attached the following image(s):
VIaCAD Extrusion.jpg (18kb) downloaded 4 time(s).
#2 Posted : Sunday, November 20, 2011 6:40:46 PM(UTC)
Hi
You can use the trim corner tool to trim to 90 degrees
You can also try grouping the lines together vs using join tool.
