Trfsrfr
#1 Posted : Thursday, December 22, 2011 3:54:20 PM(UTC)
Trfsrfr
Okay this is weird.
I open up ViaCad today and somehow my mouse scroll wheel function has changed when pressing it.
It used to be dynamic rotate.
Now its a zoom +.
How do I change it back?
It used to get changed to the big fat arrow every now and again (dynamic zoom), and I would hit the control key and it would change back to dynamic rotate.
Now I hit the control key and it changes it to no function.
I tried reading the user manual but no luck.
posh.de
#2 Posted : Friday, December 23, 2011 4:39:26 AM(UTC)
posh.de
did you have changed anything in "File > Short Cuts..."?
and check/reset "File > Preferences... > General" too.
hth,
Norbert
Trfsrfr
#3 Posted : Friday, December 23, 2011 11:20:05 PM(UTC)
Trfsrfr
I haven't changed anything. That's what is so strange about this.
And thanks for the tips, but I tried them.
Nothing works.
Of all the short-cuts I use, my dynamic rotate scroll wheel is #1.
I use it more than anything else.
#4 Posted : Saturday, December 24, 2011 7:44:18 AM(UTC)
Hi
What version are you running?
You can try holding ctrl+shift and left click mouse to drag a box and then release --> that would change it back to dynamic zoom when this happened.
Trfsrfr
#5 Posted : Saturday, December 24, 2011 12:59:20 PM(UTC)
Trfsrfr
Hi Jason,
I am running 968. And thanks for the tip.
But it didnt help.
I posted earlier that I didn't change anything. Well, I didn't change anything in ViaCad.
I did however reset my mouse settings to default, and I think that is what changed.
Unfortunately I cannot get my mouse back to where it was. I got close by using assigning the scroll wheel button to the numeral 1, then assigned a 1 to dynamic zoom in ViaCad, but it's not the same.
Before it would go to dynamic zoom when pressed, then go back to the selector arrow when I let go of it.
Now I can get it to go to dynamic zoom when I press it, but I have to physically go back and click on the selector arrow to get back.
It's a pain, but it's better.
The strange thing is that I never set the mouse to do it before. In fact when I opened up my mouse file, it was the first time I had ever opened it. I didn't even know it was there.
Now if I could assign something to the 'depress' of the scroll wheel I think I could fix it...
