Welcome Guest! To enable all features please Login or Registers.
joev
#1 Posted : Thursday, May 21, 2009 9:19:33 AM(UTC)
joev
I have the preferences for VC Pro 6 set to save every 15 commands. Right after a save, VC crashed. The only file I see was last saved an hour ago and I lost all the work for the past hour. Where is the "backup" file being saved if it's not the original file? I need to find it as VC 6 crashes quite often and I can't keep redoing what I did.
ttrw
#2 Posted : Thursday, May 21, 2009 9:32:26 AM(UTC)
ttrw
Joev, don't know what computer OS you are using, but under Mac OS X you can find the backup files in your documents folder, under 'Punch!'
Try your documents folder on Windows :)
PS, you ARE up to date aren't you? VC shouldn't really be crashing so much! :)
joev
#3 Posted : Thursday, May 21, 2009 9:37:56 AM(UTC)
joev
Sorry, yes I'm under OS X, I did a search and found the files. I'm running build 831.
Steve.M
#4 Posted : Thursday, May 21, 2009 9:42:03 AM(UTC)
Steve.M
Have just checked.
Look in location:- (this is on windows)
Documents and settings- User name- my documents- Punch- Viacad- backup
- Steve
EDIT,Cross post as I was searching :D
ttrw
#5 Posted : Thursday, May 21, 2009 9:48:30 AM(UTC)
ttrw
err, mate, we're on b834! :cool:
Ask Tim to mail you the update location :)
or is it here?? :confused:
http://www.punchcad.com/products/viacadprov6.htm
:D
joev
#6 Posted : Thursday, May 21, 2009 10:01:01 AM(UTC)
joev
:D
Then the check for Current Version under the Help menu needs to be fixed. It shows that I have the current version.
ttrw
#7 Posted : Thursday, May 21, 2009 10:28:38 AM(UTC)
ttrw
hehe! WELCOME to the wonderful world of Punch! Software! :D:D
Steve.M
#8 Posted : Thursday, May 21, 2009 11:33:59 AM(UTC)
Steve.M
eer. some are. I am still on Pro 831 with no update in sight.:rolleyes: :D
#9 Posted : Thursday, May 21, 2009 1:01:42 PM(UTC)
We're fixing a crash related to tabbing and reposting all builds to 835.
Steve.M
#10 Posted : Thursday, May 21, 2009 1:34:02 PM(UTC)
Steve.M
834 for shark as been out a week, so if it takes a week or more for these new builds to be available for pro after shark release, then its at least another week.
See ya in a week or so.
ttrw
#11 Posted : Thursday, May 21, 2009 3:18:33 PM(UTC)
ttrw
Whoops! Sorry! :eek: :o
#12 Posted : Friday, May 22, 2009 10:27:22 PM(UTC)
FYI, via private emails we found the crashes and corrupt backup files to be ViaCAD running out of virtual memory. In this particular case, turning off Use Vertex Arrays helped reduced VM quite a bit.
Steve.M
#13 Posted : Saturday, May 23, 2009 4:25:31 AM(UTC)
Steve.M
...........to be ViaCAD running out of virtual memory.
Well, VC has some serious issues with memory use. When I was building the chess knight I found at one point that VC pro was using 1Gb of memory :eek:. I minimized VC window then maximized and the memory use went down to under 50mb.
- Steve
