Hi I am importing drawing (dwg)and need to close the loop to extrude the surface, is there a fast way to do this? Thanks
Do you have an example?
Please attache a DWG-file here (if possible). DXF is running well for me (but re-import from VIA-CAD).
horst.w
GER
(64kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
