Bob La Londe
#1 Posted : Monday, June 29, 2020 2:43:57 PM(UTC)
Bob La Londe
Simple test with V9 Pro and V12 Pro side by side with the same type of solid model. That flat side of a simple cylinder. Pressure deform works on V9, but not V12.
To be brutally honest the ONLY reason I upgraded to V12 was because a customer had a newer version and I was not able to open his dead simple files in V9. There was not one damned thing in his models that necessitated they be incompatible. Its more than a little annoying to have to upgrade just to read a file and then lose features.
Bob La Londe
CNC Molds N Stuff
www.CNCMOLDS.com
thanks 1 user thanked Bob La Londe for this useful post.
MPSchmied on 7/1/2020(UTC)
Bob La Londe
#2 Posted : Monday, June 29, 2020 2:50:14 PM(UTC)
Bob La Londe
Quote:
V:VCP
Version:
12.0.0
Build:
1536
Language:
You are running the most current build. No update is necessary.
Before somebody asks. No Point Deform and Curve Deform do not work either.
Bob La Londe
CNC Molds N Stuff
www.CNCMOLDS.com
