Surface Modeling
How to select all surfaces in a plane/workplane or view?
Thanks: 23 times Was thanked: 8 time(s) in 6 post(s)
Im trying to figure out a way to select all the surfaces on a given plane (for example top view, or with a workplane). The selection keep suggesting surfaces that are in another plane/face and make is really hard.
If you haven't discovered for yourself, go to any side, top, bottom view ortho to that plane and select a shallow (only a pixel or two deep in screen vertical resolution) fence left-to-right enclosing the plane. It can be a little fiddly to orient such a view if the plane isn't the default world or one parallel to it, but it helps to activate the gripper and toggle the C key on a vertex on the plane to help with visual orientation. Only those objects completely enclosed by the fence will be selected.
1 user thanked murray for this useful post.
Surface Modeling
