darkstarh
#1 Posted : Friday, November 14, 2008 5:21:31 PM(UTC)
darkstarh
Does anyone have any idea why a single face seems to have split itself into four different faces when i try to shell? (see pic)
I've created a half pipe, spiral form, which now when i go to shell the 'inner', flat surface it will not select as one surface to shell from. Its divided into four selectable faces - so error message appears even if i select all four faces???
Hope this makes some sense
darkstarh attached the following image(s):
Picture 21.jpg (45kb) downloaded 5 time(s).
