la mouche
#1 Posted : Tuesday, January 18, 2011 4:52:36 AM(UTC)
la mouche
hello,
Here is a demonstration of the tool selection mask.
This tool is too often under-used by beginners. It's a shame because it is of extraordinary utility and will save you much time. :)
It complements very well the function and the layers and show / hide.
The principle: choose the entities we want to select, and then do: / command A (MAC)
Warning!:eek: remember to re-enable all entities in the mask, otherwise you can not select the desired entity.
http://screencast.com/t/EOKpxBTp
Thank you Tim
Antoine
