Filip
#1 Posted : Monday, January 20, 2014 4:47:56 PM(UTC)
Filip
Could you look at attached file.
Is it possible in easy way to add Draft Angle to all "external" faces.
Normaly it would be draw from rectangle and extrude with draft angle.
But what we can do if we get from outside model in STEP and do we not want to draw it from begining. I just wish to add small modification like draft angle.
maskownica.zip (50kb) downloaded 8 time(s).
