klais
#1 Posted : Wednesday, October 13, 2010 12:47:31 PM(UTC)
klais
Hi Tim,
Is is possible to make the cutting plane lines generated by the section view tools render in the "Cutting" line font? At the very least, make the cutting plane line selectable and font modifiable using the inspector. The only method I know to currently change the cutting plane line font is to construct another line change its font, and then use the eyedropper tool to transfer the font to the cutting plane line.
Regards,
Kevin
