m.marino
#1 Posted : Thursday, April 18, 2013 1:57:19 PM(UTC)
m.marino
Does anyone know if ViaCAD Pro or Shark support using a drawing tablet like a Wacom or Genius? Just asking as i realise it would most likely be in 2D mode but it would still allow for getting images in that could then be shaped to the desired form.
Michael
SharkCAD Pro v10 w/ PowerPack Pro
Lenovo D20 2x E5620 w/ 64GB RAM, Nvidia 1060
OS: Windows 10 Pro x64
MM0MSU
memphisjed
#2 Posted : Monday, May 13, 2013 1:33:44 AM(UTC)
memphisjed
Was thanked: 16 time(s) in 14 post(s)
Sorta. I use Wacom with skecthbook (autodesk), then run it through illustrator to convert to vector, then to vcp. It is a longer than desired process, but using the right tool (software) for the job is easier than hacking thru a project with a multi-almost-tool.
