Surface Modeling
Extend surf / offset surf .. same value variable ? (#3576)
Extend surf / offset surf tools Tim ... are you using the same value variable for both tools ? I'm alternating between these 2 tools and would expect to be able to set offset to -10 mm and extend to +15 mm and have these values stick Instead, when I go from the offset tool (set to -10mm) to the extend surf tool .. I find that the value has changed from +15mm to -10mm This is a simple workflow issue - but would save me lots of time as I have 100+ objects to offset and then extend (by these different values) Hope that made some sense
>>are you using the same value variable for both tools ? Yes, fixed in 961. Tim
Surface Modeling
