jfc1068
#1 Posted : Saturday, August 8, 2009 8:50:10 AM(UTC)
jfc1068
If I exit viacad, I don't want to have to reboot to be able to open it again like I do now. Obviously it does not leave memory cleanly and rebooting simply so I can use it again is a flaw in the system.
#2 Posted : Saturday, August 8, 2009 9:06:26 AM(UTC)
Hi jfc
What operating system are you using? Right click on the ViaCAD icon and goto properties then goto compatibility tab and check the run as windows xp.
jfc1068
#3 Posted : Saturday, August 8, 2009 9:16:48 AM(UTC)
jfc1068
I'm running Vista. Thanks for the input, but that still did not fix the issue.
#4 Posted : Saturday, August 8, 2009 9:24:32 AM(UTC)
hi jfc
do you get any error message when you close ViaCAD? Or what happens when you try to restart?
jfc1068
#5 Posted : Saturday, August 8, 2009 10:34:28 AM(UTC)
jfc1068
nothing happens except the hourglass appears breifly before, nothing....
#6 Posted : Saturday, August 8, 2009 11:10:53 AM(UTC)
HI jfc
when you changed the properties in the icon, did you hit apply before closing the box? I am running Vista and ViaCAD 2d v5 and have not seen an issue with open close.
