Extrusions and Grouping
I come from 2D background so apologies if this is an obvious question. As an example create a 4" x 4" x 1/4" wall steel tube 115" long. Creating it by constructing rectangle within rectangle and extruding to 115" length. After doing so windowing all and grouping all together, or so I thought. Issue is that if I select object and move it moves the extrusion only and not the underlying rectangles. If I window all it will include them and move but this is not always convenient with several parts in close proximity. Am I understanding this properly? Thank you in advance.
You sort of need to keep track which 2D lines have associativity so that when you move the 2D lines, the solid or surface associated with it moves along with it. Moving the solid doesn't move the 2D lines as you have found out. I think you also need to figure out how drag select in both direction works since drag select from left to right does something different than going from right to left especially when thing are in close proximity. Cheers,
1 user thanked rockyroad_us for this useful post.
also very helpful for selections is "menu -> window -> select mask" to select special object types
1 user thanked Guest for this useful post.
Gentlemen, Thank you for the direction. The best to you! Sincerely, Chris Williams
After Rockyroad's clarification and Guest suggestion have come up with this resolution.
#1 Create two smart polygons for the tubing profile.
#2 Extrude the shape.
#3 Select both polygons and group. NOTE: Group after the fact as you can not extrude a group.
#4 Rename group the the part spec., like 115x4x4x.25, or 115" long, 4 x 4 tube and 1/4" thick wall.
#5 To select and move that component, as solid will follow base lines, activate mask to groups only.
#6 Select appropriate group and move assembly.
Edited by user Thursday, November 13, 2014 6:34:48 PM(UTC)
