rjs
#1 Posted : Tuesday, December 2, 2014 8:17:46 PM(UTC)
rjs
I am posted this question a couple of times but as part of another question and have have not really found an answer.
for example I create a cube 20x20x20 in the center of the screen and enter 20 in the Y coordinate press enter and nothing happens. See the attached. If I click on a anything the coordinates disappear and do not show back up when you click on the cube again.
When I do this with a sphere it moves the sphere by 20mm along the Y axis as expected. if I click off of the sphere the coordinates disappear but with a Sphere when select it again the coordinates reappear. The seems to work with all of the other solids, even if you create a cube using a prism, but not for the Cube.
Am I missing something?
Randy
rjs attached the following image(s):
ViaCAD coordinates.JPG (128kb) downloaded 8 time(s).
