hello
I did not manage to connect your forume.
I have the following error:
Server Error in '/' Application.
'YAF.Core.Data.TryInvokeMemberProxy' does not contain a definition for 'repository'
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: Microsoft.CSharp.RuntimeBinder.RuntimeBinderException: 'YAF.Core.Data.TryInvokeMemberProxy' does not contain a definition for 'repository'
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[RuntimeBinderException: 'YAF.Core.Data.TryInvokeMemberProxy' does not contain a definition for 'repository']
CallSite.Target(Closure , CallSite , Object ) +216
YAF.Core.Model.<>c__DisplayClassa.<ListTyped>b__8(Object r) +989
CallSite.Target(Closure , CallSite , Func`2 , Object ) +95
YAF.Core.Data.DynamicDbFunction.GetTyped(Func`2 getFunction) +864
YAF.Core.Model.CheckEmailRepositoryExtensions.ListTyped(IRepository`1 repository, String email) +202
YAF.Pages.recoverpassword.PasswordRecovery1_VerifyingUser(Object sender, LoginCancelEventArgs e) +592
System.Web.UI.WebControls.PasswordRecovery.AttemptSendPasswordUserNameView() +65
System.Web.UI.WebControls.PasswordRecovery.OnBubbleEvent(Object source, EventArgs e) +96
System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +52
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3707
Do you have a solution please ?
My eMail =
[email protected]Claude Azoulai
