Is there no library of fixtures for floor layout plans as in plumbing electrical and other items needed in floor plans? Also when I convert to DWG file to transfer to others the dimensions are changes to another format. I have setup as architecture at a 1/4 scale and it comes out in decimals in dwg file
Hello Michael
Did you look in the symbols area in the concept explorer? From the file menu goto windows then concept explorer then its the third tab called Symbols.
When you exported the dwg what did you select in the options?
(15kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
I see some of them there but there is a yellow triangle when I hover the cursor over them
Originally Posted by: michaelclark I see some of them there but there is a yellow triangle when I hover the cursor over them
Michael
Just click on the symbol hold mouse button and drag it into the drawing.
