Surface Modeling
subtracting/loosing half of surfaces ??
I have one skinned surface and two surfaces of revolution and would only like "half" of all three. how do I subtract/loose/trim/...... half of a surface?? imagine cutting three surfaces on a band saw and removing half of each to enable "seeing" the inside of the surfaces.
thanks!!
Art
artesmith@earthlink.net Art Smith attached the following image(s):
(14kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 631 times Was thanked: 103 time(s) in 65 post(s)
You can use the Infinite Plane Tool, take care of the orientation, then apply the Split Surface Tool et voila ! Regards G
1 user thanked GARLIC for this useful post.
progress, but still no joy! splitting the skinned surface "ADDS" a plug.....??
Art
artesmith@earthlink.net File Attachment(s):
splitting file.sfx
(348kb) downloaded 14 time(s). Art Smith attached the following image(s):
(26kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Exported as .sat, import as .sat create a plane, use plane as clipping plane.
Untitled 1.sfx
(254kb) downloaded 13 time(s). L. Banasky attached the following image(s):
(31kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
Surface Modeling
