nboersma
#1 Posted : Friday, August 26, 2016 8:37:33 AM(UTC)
nboersma
I have a template with title block but it does not fill the page. Can you make a drawing template that is about the size of the page?
If I then draw an object, it will not fit on the page. Can you reduce the size of the object to fit the page but keep the dimensions to scale?
#2 Posted : Friday, August 26, 2016 8:53:24 AM(UTC)
Hello nboersma
Why not draw the objects full scale 1:1 and dimension. Then you can scale the title block/border to fit around the object. And fit to the printed page when printing?
In answer to your questions you can scale the border and title block any size you want and save as a new template
Yes you can add a draw view and copy and paste the object in the draw view. Then dimension it
