Bob La Londe
#1 Posted : Friday, October 21, 2016 10:42:24 AM(UTC)
Bob La Londe
Often I want to copy or cut an entity and paste a duplicate. If I hit Ctrl+C and Ctrl+V without hitting anything else I get a paste in the same location which 99.99% of the time is what I want, because it relates to other entities in the working file. However, if I copy something, do some work, and then paste it a few steps later it almost always pastes in a different location. Is there a setting I can change to force it to default paste in the same coordinate location where it was cut or copied from?
Again, I don't recall this being an issue in V7 or V8.
Edited by user Friday, October 21, 2016 10:43:42 AM(UTC)  | Reason: Not specified
Bob La Londe
CNC Molds N Stuff
www.CNCMOLDS.com
defkon
#2 Posted : Friday, October 21, 2016 3:05:28 PM(UTC)
defkon
Hi Bob,
i think this is what you search for.
defkon attached the following image(s):
Paste options.jpg (132kb) downloaded 8 time(s).
