Is there a way to delete a custom color once created? Steps to create were as follows: #Select object. #Right click and select color. #Define custom color. I inadvertently created a color not needed but now see no way to delete it. Is anyone aware of how to do this. Have looked at user guide and searched this forum without success. Thank you in advance.
Originally Posted by: CNW Is there a way to delete a custom color once created? Steps to create were as follows: #Select object. #Right click and select color. #Define custom color. I inadvertently created a color not needed but now see no way to delete it. Is anyone aware of how to do this. Have looked at user guide and searched this forum without success. Thank you in advance.
CNW,
If you are on Windows you can clear the custom by selecting it and setting all 3 RGB back to 255 and assigning it will "clear" the existing. There is no harm leaving a custom color unless you run out of room but you can assign new colors over an existing one anytime.
(22kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
