Andrew Gray
#1 Posted : Monday, February 27, 2017 2:52:37 AM(UTC)
Andrew Gray
Hi all
I'm having an issue with the push pull tool
If i pull out a surface (face) so its coplanner with another face, that face doesn't highlight.
Is there trick to get it to work?
Thanks Andrew
rokoko
#2 Posted : Monday, February 27, 2017 12:58:35 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
did you check the option "face snapping" in inspector -> gripper?
Andrew Gray
#3 Posted : Monday, February 27, 2017 2:12:09 PM(UTC)
Andrew Gray
Perfect..thanks again
Andrew
