Andrew Gray
#1 Posted : Sunday, May 14, 2017 12:16:30 AM(UTC)
Andrew Gray
Hi All
I'm looking for a workflow to align a inserted profile (steel section) with my construction lines
see attached, align the steel section blue direction with the green line
Andrew
Andrew Gray attached the following image(s):
ALIGN WITH LINE1.JPG (78kb) downloaded 8 time(s).
murray
#2 Posted : Sunday, May 14, 2017 6:40:11 AM(UTC)
I'd put a two-point block on the line, use magnet to put the profile on the face with the alignment you want, adjust with move and rotate if it's needed.
Andrew Gray
#3 Posted : Monday, May 15, 2017 3:33:27 AM(UTC)
Andrew Gray
Thanks, All
solved with rotate three point tool
Andrew
