Sheet view - issue with layers
Hi All
not sure if this is a bug, but see screen shot
You see via the layer list that profiles and skeleton are OFF
yet the profiles and skeleton can be seen in the draw view
Andrew
vc10 build 1318
Andrew Gray attached the following image(s):
(220kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
Hello Andrew If this is a single draw view there are two types specified by a drop down when you first select the tool. 1. The original draw view contains all layers of objects pasted in 2. New option that allows layers to be turned on/off. The layers list is in the draw view options drop down that you need to use to turn visibility on/off. Regards Jason
Hi Jason, Thanks for the answer I'm using your option 1 the issue with using option 2 is that there is NO polyline edge style I solved my issue by selecting ALL and changing the layer Andrew
