malcolmD
#1 Posted : Wednesday, July 12, 2017 4:27:12 AM(UTC)
malcolmD
The Text in Balloons (or other shapes) in the Callout dimensions is offset from the baloon, and is obscured by the leader when the balloon is to the left of the dimension arrow. Moreover, I cannot find a mechanism to adjust the position of the text as one can in other dimension types.
Am I missing something?
Malcolm
(the green callouts on the left of the drawing show the issue...)
thanks
Edited by user Wednesday, July 12, 2017 4:56:50 AM(UTC)  | Reason: Not specified
Fit-out-Plumbing1-2da.vc3 (328kb) downloaded 9 time(s).
rockyroad_us
#2 Posted : Wednesday, July 12, 2017 6:47:52 AM(UTC)
rockyroad_us
Under the dimensions tab, change the value of the "first offset". It enlarges the circle. But there's something wrong because it is 10.0 and when retyped to 10 it changes the circle but it is not really 10.0.
Tim also I've noticed this through previous versions that when dimensioning in a new file ANSI does not stick right of way despited being the default. For instance do a dimension, and then just pull down the ANSI tab despite being already selected and the arrows change to ANSI arrows or the ANSI settings what ever they are from those settings. Which begs the question, what are the initial default dimensioning standard?
malcolmD
#3 Posted : Wednesday, July 12, 2017 7:07:06 AM(UTC)
malcolmD
Yes, thanks I found the offset did change the size of the circle, but the text offset is still wrong, and if you use a call-out without the circle then the leader lines cover the text (as shown in the sample I provided)
M
#4 Posted : Wednesday, July 12, 2017 7:08:46 AM(UTC)
Hello Malcolm
The balloon dimension can be modified in the inspector object properties data tab. The width controls the circle. The check box for scale with text size will allow all parts ofthe callout dimension to change with the a change in text size. However when the box is checked it will start with the current sizes and just scale from there. So you want to uncheck this box make changes in the inspector so the callout is the size you want text and circle.
malcolmD on 7/12/2017(UTC)
rockyroad_us
#5 Posted : Wednesday, July 12, 2017 7:24:38 AM(UTC)
rockyroad_us
M
Negative. The file you posted all have circles. at least all four pointing to the same spot. I didn't see any other callout. You can change the frame type to callout which is the one without the circle but the text looks good.
I'm sure you figured it out by now.
thanks 1 user thanked rockyroad_us for this useful post.
