Hello everybody.
I have to export an isometric 3D view to illustrator. I am well able to recover my file in illustrator, but the curves and circles are cut into smaller lines. I tried not to choose the option "Polylines" in the draft view, but then the export always fails. Do you have a solution so that I can recuperate continuous curves in illustrator ? Thanks in advance for your help.
jeant attached the following image(s):
(22kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Hello Did you try exporting as dwg? Regards Jason
Hello Jason, It was a good idea, but unfortunately it does not work. I tried DWG, DXF, EPS .... no curves :-(
