NeuTechFLA
#1 Posted : Saturday, March 3, 2018 6:55:43 AM(UTC)
NeuTechFLA
Morning All,
I know I may be stating very, very old news with regard to 2D PDF of of VC/Shark. I am still a noob on the software and I have been busy trying to get proficient.
What that said, I noticed that 2D PDF creation is not in the "Export" options nor the "Save" options. This led me to look in the "Print" options and it so happens that my printer (HP Deskjet 2130) has an on-board PDF utility. After much trial and error I was able to "Print" (see attached) using its utilities and saving the PDF. I did not use a "Print To File" command within Shark. Rather when prompted to print I chose "Print by Layer" and used "Sheet View to Sheet View" as the items to print.
I am not sure if this "informs" anyone of anything but I thought I would share my effort.
Edited by user Saturday, March 3, 2018 6:56:34 AM(UTC)  | Reason: Not specified
zxcvbnm.pdf (18kb) downloaded 11 time(s).
